I cannot copy from HDD to optical disk, because DVD
drive is not working. Where to get DVD drive E143838?
emma
SOURCE: dvdr 3455H/97 hard disk unable to reboot
download firmware 5.04M from Philips and follow the "release notes" (below download icon)to burn it in CD ...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=HK&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&grp=HOME_ENTERTAINMENT_GR&session=20090613081403_116.48.214.244&ctn=DVDR3455H/97&mid=Link_Software&hlt=Link_Software
I tried it! should be OK
SOURCE: Is there firmware update for Philips DVDR 3455H ?
Well you get your firmware from below link -
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_HARDDISK_RECORDERS_SU&session=20090905122441_125.63.122.112&grp=HOME_ENTERTAINMENT_GR&ctn=DVDR3455H/37&mid=Link_Software&hlt=Link_Software
Good Luck!!
Thanks
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board or the drive mechanism
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Now certain cleaner disks are not read and so will not be tracked. but the best is for cleaning manually the laser head eye with a cotton bud very softly and without any pressing of the lens eye.
If there is still no result then watch the DVD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to have issues and the possibility of the optical head being good.
Finally try to see if the set records on a DVD with a given signal source. If not the fault is confirmed that the main PCB, processing section is faulty.
yes I do have the same problem. if you could suggest a solution please!
