have a philips dvdr3575h/37 dvd player will only play some discs, others load but does not play...
(More)
have a philips dvdr3575h/37 dvd player will only play some discs, others load but does not play front panel show -4:00:00:00 on the screen will not access playback of the dvd
I have a DVDR3576H/37 that jumps to Jan 2035 every few days. The clock setting is setto Manual, so...
(More)
I have a DVDR3576H/37 that jumps to Jan 2035 every few days. The clock setting is setto Manual, so it's not the Automatic feature. Please advise. Thanks
From my Philips 3570h when i connect my USB with avi files it will only play the audio with no...
(More)
From my Philips 3570h when i connect my USB with avi files it will only play the audio with no pictures!
Hi. Our DVDR355R-37 has a low luminance output! The picture looks darker, with excessive chroma and...
(More)
Hi. Our DVDR355R-37 has a low luminance output! The picture looks darker, with excessive chroma and a lack of brightness. This happened right after the warrenty expired!! Is there any secret code or some other way that I can adjust the picture luminance
our dvd player dvdr357sh makes whirring noises, not constantly sometimes it is ok but then out of...
(More)
our dvd player dvdr357sh makes whirring noises, not constantly sometimes it is ok but then out of the blue it starts and we have to turn it off.
I have a Phillips Hard Disk/DVD Recorder and a 8 GB SanDisk Cruzer Flash Drive. I put a movie on the...
(More)
I have a Phillips Hard Disk/DVD Recorder and a 8 GB SanDisk Cruzer Flash Drive. I put a movie on the flash drive in AVI format, which I am sure that they are able to play, but it's not registering that there's is any data on the drive when I put it in the DVD player. So I am wondering if it is the DVD player, the memory stick?? What it could be. The movie plays fine on VLC. Maybe it needs to be in a WMA format, which I know it plays for sure so if that's all it is does anybody know a good program for converting them from AVI to WMA??
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
