I recently installed a new Frigidaire electric stove. The burners and oven heat up but not enough to cook anything. Do you have any ideas what may be causing the problem.
Loud pop means electrical fault occured. There may be and internal fuse in the oven that blew. Probably blown oven element but certainly open circuit to timer. Remove back, check for supply to oven timer. If supply is there, the timer can be bypassed to allow for oven element to work as clock replacements are very expensive.
Your problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
I hope someone can help me. My range made a loud pop and now my oven does not work at all. The Clock does not work. However, the four top burners work with no problem. Can someone tell me what the problem is and How do I fix it?
