Question about Frigidaire FEB27S5A Electric Single Oven
We own a frigidaire stove it's a year old was working fine yesterday turn on to bake a turkey and oven was not heating up the relay kept turning on and off (clicking) Same problem - periodically the stove will not heat - not the stovetop units or the stove. The clock works and power is on the stove, but none of the heating elements warm at all. If it is a thermostat...how can it be reset?
SOURCE: My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Posted on Dec 08, 2008
SOURCE: FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Posted on Aug 24, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
SOURCE: Frigidaire double electric oven #pleb30t8cc
I have seen and have had bad soldier connections on the relays to the boards. check boards.
Posted on Feb 10, 2011
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
