Dishwashers Logo
Anonymous Posted on Mar 26, 2012
When switching on machine to start program it trips electricity
Trips electricity
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
154
Points
6
Dishwasher is short
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
tip
My Saeco has started to trip electrical fuzes when switched on. Started when...
Here's a few Tips for the countless number of people having problems with the Saeco Line Super Automatics Machines.
These are more Suggestions if you will on what you can do that will help your machine last as long as possible.
Tip 1. Surge Protector. Get one and use it on your machine. About half of the problems associated with saeco's revolve around a power....or lack of power problem.
Even the smallest Surge can send your machine out of whack. Worse yet if it loses power while in mid cycle, it can jam the brew system.
Tip 2. Bottled Water. Coffee is 90% Water, so by contrast quality water will increase the quality of the cup. Try an artisan water like fuji or italian bottled water, or even filtered water. This small tip will not only keep your machine insides clean, it'll make for a way better espresso.
Tip 3. Ditch the Oiley Beans. All Super Automatic Espresso Machines, even the 20,000 dollar commercials have one major flaw. They Hate Oiley Coffee Beans. Why? Its simple, Oiley Beans Gum Up the inside of the grinder and brew drive system and clog them.
Another Reason to Ditch Oiley Beans? Being a 2nd Generation Artisan Roaster Oiley Beans scream a few things. Oiley beans are usually over roasted. The oil on the beans isn't a good thing, the oil represents the flavor oils from inside of the coffee emerging out. Once they become oxodized the coffee loses flavor almost immediately. Oiley beans are also a sign of beans that have aged, which again, is not a good thing. Proper Espresso Should have very little to no Oil on the beans with a Uniform Color Darker then a city roast.
They Only Time there is an exception is with a french or dark roast, where the ashy tones are allowed.
Best Advice here is try to find a local roaster. The quality is usually better then any of the commercial corperate counterparts and your actually supporting people like you. What kind of people is that??? People who have a genuine love for coffee and want people to share that love.
Tip 4. Descaling. Even with bottled water the machine should be descaled every other month. You have a variety of options here. I personally use cleancaf for its ease of use and the fact every packet has the instructions on them.
Tip 5. Brew Group Cleaning. Clean the Brew Group with Soapy Water. No chemicals necessary. You'll also need to purchase some silicone lubricant which is sold by saeco. It must be food grade. The lubricant is applied around the inside ridge of the puck area of the brew group. The first 3 coffee's on the machine should be tossed there after to clear it of residue.
Tip 6. Turn Machine off after each use. When you don't need it, don't leave it on. Leaving it on for long periods of time creates air pockets inside the boiler of the machine and can dry out the inner gasket of the boiler unless you have the new J Style Boilers that come with the newer lines from Saeco.
Tip 7. Be careful of your grinder. Firstly, I tell people every day. This machine is not ment to make commercial quality espresso. Its just not possible. It was ment to make for a better experience than the traditional italian moka pots that make fairly terrible coffee. If you want a stronger coffee, then the answer is in itself, try other coffee's.
The machine enhances good coffee, and by comparison, enhances the flaws in bad coffee. Inferior Coffee's will have little crema and bad taste. The machine will try the best it can to accomodate the coffee. The Elongated pre infusion cycle help take even the worst coffee and make it look like it gives increadible crema. The proof comes afterwards, where the crema will decipate from the bad coffee's but will stay strong on the true espresso blends.
Setting the grinder any lower then 2, regardless of the model, it warrent for clogging and/or damaging the unit. If the coffee is too fine, it'll clog the unit, and usually cause the brew drive to strip the gears and even worse, i've come across cases where its even broken the brew drive.
This concludes my Tips for Keeping your Saeco functional post. I hope this helps people and gives them incentive to step out of the box when it comes to conventional coffee's that are on the market.
2answers
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
1helpful
My washing machine keeps tripping the electricity
there is a shot on the power supply board, that's why it trips. Have is checked.
2helpful
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
1helpful
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
1helpful
electrical short in m/c.could be heating element. regards
2helpful
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
