I have this problem in which my monitor starts to turn off everytime I turn it on wherever I leave the monito off for 5 minute while keeping the cpu on.I tried another computer just in case and the same thing happen.Anyone knows hat I should do?
No power to the monitor even with power plub installed. No orange or green ledNo power to the monitor even with power plub installed. No orange or green led
You can't post conmments that contain an email address.
If I understand you problem correctly, your monitor is turning off when it remains idle? Does it come back on when you use the keyboard or move the mouse? If so, then this could just be caused by the computer's power-save settings. This can be adjusted by right clicking on the the desktop and selecting propeties. Go to the screensaver tab and click on the power button. From here, you can either set the "Turn Off Monitor Time" to never, or to a greater period of time.
No signal is not a problem with the monitoe unless the cabe is disconnected from either the PC or the monitor ends.
If the cables is securely attached at both ends it indicates the PC is not sending a video signal to the monitor.
Could be the PC hasn't booted up propperly.
Turn the PC off , wait 2 minutes and turn it back on.
Observe any lights on the front of the PC , especially disk activity light.. it should flicker .. alot.
If not then you have a PC issue not a monitor issue
you could have a problem with your phone that needs repair or it could just be a bad battery. I wowuld take it back to the provider or wherever you got it an tell them you want another phone, if they refuse ask if you can at least have a new battery. Try the new battery and see if it corrects the problem.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages. Good Luck!
maybe you have a "cold solder", if unit keep turning on when it's cold, is it...
If you have the skill to open it and you have a solder iron, maybe you can try to fix it, if you don't leave it to the repairman.
I did that and it still happens.
