Can't turn oven on LOC appears in screen.
The Control Lock feature is on. Press and hold 9 and 0 together for at least 3 seconds to toggle off the lock. It will beep when the lock turns off; I've found that you sometimes have to hold the keys for closer to 5 seconds. This feature is useful when cleaning the control panel and to keep small children from accessing the oven. Repeat holding 9 and 0 together to toggle the lock on. If you look closely at the control panel, you will see a line under the two pads with Control Lockout underneath the line.
LG has the manual for the LR30855ST on their product support site: http://www.lg.com/us/support-product/lg-LRG30855ST .
I hope this helps.
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Hello
& Welcome to FixYa
Press
& Hold the START PAD for 20 seconds to turn off LOC error. Please get back
to me if you have any other questions.
Kevin
