20 Most Recent Electrolux 30 Inch White 30" Electric Slide In Stove Range Ew30es65gw Questions & Answers
Most likely control pad is defective
Electrolux 30... | Answered on Nov 03, 2017
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Electrolux 30... | Answered on Sep 28, 2012
Usually all you have to do is hold your finger on the icon until it either locks or unlocks. Otherwise contact Electrolux:
USA
1.800.944.9044
Electrolux Home Products, Inc.,
10200 David Taylor Drive
Charlotte, NC 28262
Canada
1-800-265-8352
Electrolux Canada Corp.
5855 Terry Fox Way
Mississauga, Ontario, Canada L5V 3E4
Electrolux... | Answered on Apr 28, 2019
Since there are gas fumes this is a dangerous situation and should really have a professional with the right equipment to find the leak.
Electrolux... | Answered on Feb 09, 2019
Could be a bad breaker, or a wrong breaker, in the install instructions it will list the required amperage rating for the breaker. If the breaker is over 7-8 years old, could just be bad internally.
Electrolux... | Answered on Jan 08, 2019
An "F11" typically stands for a shorted keypad. You can reset your appliance by unplugging it or disconnecting power for ten minutes. If you perform this step and continue to receive an "F11" it could be an issue within your EOC (Electronic Oven Control) and I would recommend having a professional come out to properly diagnose your range
Electrolux... | Answered on Dec 25, 2018
Try unplugging it for 5 minutes
Electrolux... | Answered on Dec 18, 2018
Searpartsdirect.com or repairclinic.com
Electrolux... | Answered on Nov 21, 2018
What about it?
Electrolux... | Answered on Oct 17, 2018
Electrolux 30 Inch White 30" Electric Slide In Stove Range Ew30es65gw Logo
3 questions posted
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Kitchen Ranges
Most Popular Question
stoves oven
  • Kitchen Ranges
