Did a system recovery to earlier time and restarted. Now it's stuck in a startup loop. This is what it does: HP screen, windows logo, flashes blue screen, prompts to start windows normally. If I select start normally, it goes through that process again.
1. Open the Start Menu.
A)
Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A)
Click on the Recovery icon.
B) Click on the Open System
Restore button.
A
'System Restore' window will appear. Here you will have to check "Restore
computer to an earlier time'
A)
Click on the Next button
Now
you will find a window with Dates, Description and Type,
Note:
It is better if you could remember from which date you are facing the issue,
try to select a date prior to that date.
The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
A)
A)
Restore button.
A
A)
Now
Note:
The
A)
A)
Restore button.
A
A)
Now
Note:
The
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration
utility' window click on 'startup' tab then uncheck all the applications except
your current antivirus and press apply then 'ok' and then 'exit without
restart' option.
Just do the
following steps and your issue will be resolved.
1) Delete
all unwanted data from Drive C.
2) Delete
all data that you have copied from Drive C to External HDD
3) Open My
computer and go to Tools---> Folder Options---->Click on View Tab---->
Check 'Show hidden files and folders' and select OK.
4) Go to
C:\Documents and Settings\Administrator\Local Settings\Temp and Delete
everything that you see inside Temp Folder
5) Go to
C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to
Delete all the folders starting and ending with $ sign.
6) Empty
Recycle bin and restart the PC and your issue will be resolved.
Problems starting up a PC can be tricky to fix, since Windows hasn't had a chance to load its arsenal of troubleshooting tools. Some people simply give up and reinstall Windows.
Startup Repair can prevent a time-consuming reinstallation by diagnosing and repairing problems that prevent Windows from starting.
Startup Repair is designed to start automatically if Windows detects a startup problem. For more information about using Startup Repair, and what to do if it doesn't start automatically
here is my solution... when you boot your window when you're middle in dos loading press F8 and select boot in safe mode... then when you are in windows click start --> all programs ---> accessories---> sytem tools ---> system restore... hope you back up your windows.... try to restore your window in earlier time...
HOPE IT HELPS AND GOD BLESS
Switch ON the PC, boot the PC in
'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System
Restore
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select the first date that you see in Bold.
The
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot your problem should be resolved.
If you feel that my answers have helped you getting
solution to your problems then please give a vote.
Thanks.
I did the suggested "on startup time press F8 for no of times.From option click repair and continue with instruction,When asking for password ,change user name and click enter" I don't have this option in my advanced options menu. These are the following choices:
Safe mode
Safe mode with networking
safe mode with command prompt
Enable boot logging
Enable VGA mode
Last known good configuration <--Tried that already
Directory services restore mode
Debugging mode
Disable automatic restart on system failure
Start windows normally
Reboot
Return to OS choices menu
