I had the same problem with the door latch breaking off and i get the (close lid) flashing cane you buy a new latch or is the printer junk
I have seen this problem with this series of printer. (all the ones shaped like this ie. 5150) The lid will not close all the way on the right side (this is where the lid triggers the door open/close sensor flag). Somehow the sensor flag gets out of alignment over time where the top can't close properly to trigger it. The simplest solution is take something and wedge it where the tab from the lid would come down and make contact with this sensor flag. Print with the lid open or set the lid down on whatever you use to trigger the sensor flag. Hint: when testing and problem solving in house, I use a small piece of paper folded up several times to trigger door open/closed sensors that way I can watch the printing process and diagnose problems.
Inkworks
866-381-0541
Thank you for your inquiry, David Castro!
I understand that your Frigidaire washer is not working after the lid piece became broken. If the lid piece is not latching properly inside of the door latch then your washer is not registering the door is closed and will not start. You may need to have that piece replaced I would recommend having any electrical component replaced by an authorized technician. I hope this is helpful. -Matt
