One day i just went on to my laptop and the screen is pixelated and when i watch movies or go on youtube, search things up etc. I cant see it very well because the screen is pixelated.
Hook spare monitor to video output, if okay! the LCD panel is bad and needs replacement. If symptom is the same, it means the video graphics card is defective usually built into the motherboard.
? 4:10
https://www.youtube.com/watch?v=ge4Wo9FQf8w
Oct 5, 2014 - Uploaded by 21NorthMedia
How to watch Movies & Photos from your USB Flash Drive via the USB Port on your Flat Screen TV.
? 2:40
https://www.youtube.com/watch?v=jOhvbdVkPaM
Nov 10, 2012 - Uploaded by DIYallday
I'm trying to play movies from my USB port, but when I plug it I can't .... My LG 47" TV will recognize and open the flash drive, but shows empty.
Hi, to watch movies on YouTube you need: Internet Connection Internet browser a computer So, here's what to do: 1) Open your Internet browser 2) In the adress bar write in www.youtube.com 3) At the top of the page there's a search box, type in the name of the movie you want to watch and you're ready to go. Please note that on YouTube there are not much of the full length movies, you can buy those online.
When you wake the computer up from sleep, eventually some of the windows files become corrupted. I recommend that a proper shut down be done when not in use. Now to try and address your problem, do a system restore and take it back in time before this started, if successful should resolve your issues.
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
your videoes have a small pixel say 320x240 so when you blow it up to say 1440x900 the player has to ADD pixels that dont exist. so you get an unclear picture.
This sounds like the symptoms of a known issue with the DV2000 series. I don't know if they're still doing it, but a few months ago they were fixing them free even out of warranty. Read the following article by HP and see if it applies to your situation. Good luck!
Try this..
Open Movie Maker
Goto TOOLS - OPTIONS
Open the Compatibility Tab
Remove the ticks from ALL filters EXCEPT the Microsoft ones.
If there are only MS filters, the remove the tick from those also.
