SOURCE: I have a Samsung SP2514N
If your using an external drive case, the jumper pins should be set at "single". If that doesn't work you can try moving the jumper till the drive shows up, or use no jumper at all. If it still doesn't work after trying all jumper positions or no jumper then the drive could be bad. Make sure to power off the drive before changing the jumper.
