Acer Aspire 5100 Notebook Logo
Posted on Nov 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pc to tv
Whats needed for pc to tv
Anonymous
Level 2:
Sergeant:
  • Expert 264 Answers
  • Posted on Nov 01, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
264
Questions
0
Helped
76686
Points
707
You must be having a S-Video port on the laptop. You need to have the S-Video cable.
Click on the following links for the pictures.
S-Video Port
S-Video Cable
I am sure that it would help. Please do rate the solution
All the Best
Sammy
How to connect HP PC to Samsung Version SQ01 via USB?
what does video's mean?, endless answers, possible.
no Idea what you are attempting at all.
(my only oblique clue was that SQ01 teaser)
if you have an unstated PC and want to watch Netflix say so.
or if you want to watch local PLEX videos say so. (*.mkv)
I'm pretty sure you meant stream videos not look at DVD.
and USB is NOT IT.
this is the LCD panel name not the TV, the TV that uses that SQ01 panel (one) is LN46C630
on the back of the TV is a tag telling you what you own
tell me what you own makes answers 10x more easy.
here is my wild guess. sorry, 45" wide TV.
https://www.samsung.com/us/video/tvs/LN46C630K1FXZA-specs
when I go there it tell me this RELIC TV is NOT SMART
has no streaming APPS. (box says NO apps)
so my guess is you forget to post like this.
I want to use my PC to watch netfix (or any streaming source)
but my TV is NOT a SMART TV
I have PC (unstated HP ) and want to that with my PC.
The TV is no use, to me or my PC the TV is useless to stream
but It is TRUE the PC can (if not too old) can be the SMART part
yes, you connect the PC to your enternet
and go to Neflex.com , log in and bingo but alas the PC screen is dinky do small and buy hdmi cable and connect PC to TV hdmi
and in the TV push (remote inhand) Input select and HDM1 (what you picked) and bingo TV is not large screen to PC.
on HP laptop the hot key is Fn+F4, to use external screens.
if the HP is desktop say so and we can talk that all day, I you want.
the other way, I have 1 TV in the guest room , huge 55"
that is not SMART also, like yours. just has inputs hdmi.
so on goes the ROKU box for $99 and now IT is a smart TV
no PC needed or wanted there.
so now I answered 3 ways possible to stream vids/.
1helpful
Pc reads tv through hdmi but tv says no signal still what do i need to do?
The TV reads the PC via the HDMI out from the computer. You must make a direct connection from the PC to the HDMI input on the TV with a proper HDMI cable. Once that is established, you need to be certain what HDMI Channel is represented on the TV, HDMI #1, 2 or 3? Etc. Best you turn on the PC AFTER all connections are made and the TV is in full operation and the channel HDMI 1,2,or 3 etc. are on. Now turn on the PC and see if you get a connection. You may have a picture if you are streaming a video, and NO sound. If so, reset the Audio by clicking on the speaker icon at the lower right of your computer screen, and in the Volume Control Options select the output you wish to use.
1helpful
Connect to tv
If you TV has an hdmi in then all you would need is an hdmi cable...if it doesnt then youll need an adapter to convert to what ever inputs your TV has
What cable do I need to conect my HP computer to my Element TV?
check computer and tv for same type of conection - VGA, DVI, HDMI
I a week ago bought a insignia 42inch 1080 LCD tv and love it but I need 2 know what do I need 2 use the pc feature ..... So far I have Internet , a netgear router , hd cable tv what else do i need ?
The PC feature is so that you can use the TV as a monitor for your PC, not so you can use the TV AS
a PC.
To use it as a monitor, you need a mini-D15 male to male VGA cable and a 1/8 inch stereo male to male audio cable.
I have a philips tv model 47pfl5704d. what cable
IF, your PC indeed supports TV out, then the Cable usually is SVGA or RCA, connectors. The PC must be configured to activate BOTH screens, ie: enable desktop, to be spanned or mirrored, , the Resolution on TV should only generally be set to 800x600. The correct Drivers must be installed. Must connect to TV before ya start PC too.
What wires / connections do i need to run my home pc through the t.v
Depends on what hookups the Tv and PC have. Newer laptops have a HDMI jack, otherwise the external monitor jack will do. Then the TV must have a monitor hookup. Most likely not. So then you'll need some type of a conversion cable to go from PC to TV. Check your local Best Buy for the cable.
Connection from pc
Firstly you need to know what video ouputs you have on your PC and then what inputs you have on your TV.
From the spec of your TV - you have HDMI, S-Video or VGA. If your PC has any of these outputs - you can connect them, you'll just need the corresponding cable.
2answers
Cannot get sound from desktop to flatscreen.
You have problem with wiring. You need two separate wires, 1 - pc-> TV (video), other pc->TV (audio). Audio cable - minijack to rc
Pavilion desktop to sharp aquos pc input
what type of cable you are using?
do you have video card in your PC?
* lower the resolution on your PC and connect the TV.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
