Maddogmic, Thanks! You're solution was pretty easy to do. Just one question....which of the three lower adjustment screws should I turn. I assumed the left one was blue per your order given in the note below and turned that. They are probably labeled but there was white paint over the writing and it was very hard to see. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the bottom is the blue, red, and green adjustments (they should be labled). All you have to do is turn adjustment screw slightly to the left(or counter clockwise) and it should clear right up.
