20 Most Recent
HP 2133 Notebook Questions & Answers
My laptop was on when
I'm Working as a Technician! You can explain your laptop problems to me through Message or dial my toll-free number +1 (833) 493-0111 . Regards
Broken screen
The replacement screen itself can be obtained on eBay for $80-$120. I searched for "hp 2133 screen" in "PC Components" and came up with several results. I have replaced the screen for a friend before on an HP laptop, and she had purchased the replacement screen on eBay. It wasn't exactly "hard" to do, but it was time consuming. The replacement screen was of good quality and arrived in new condition. It is still working too.
Can not turn on the wireless capability for the HP 2133 and there is no key and I don't know the function key either
Step 1: Enable Bluetooth on a HP Mini b> The HP Mini has built-in Bluetooth capabilities that allow you to connect keyboards, mice and other Bluetooth-enabled accessories without using wires. Before you use the Bluetooth on an HP, you first need to enable it. Powering the Bluetooth on the computer on is easy to do, however, and should only take a few Click on the start menu from your computer's desktop. Select "All Programs" from the options on the Start menu. Choose "My Bluetooth Places" from the program menu. Choose "Power On" from the menu when it appears. Select "Search for new devices" from the menu to locate and connect your Bluetooth accessories to your Mini.
2133 hp notebook freezes at startup repair disks that came with do nothing
The DVD driver is critical to loading the operational system, did you try setting the boot order on the usb storage device, from your comments you have done that. The only other thing you can try is remove one stick of ram and power up, if no! remove the second one and replace the first piece and try again, "long shot" but worth the try. If none of these work you may have a hard drive issue, or windows files have been corrupted.
Hank problem
Its a serious problem . The most problems are the harddrive. Replace the harddrive. KeenePCrepairs
I HAVE HP MINI 2133
I will advice u 2 uninstall all ur audio driver and reinstall they.It works!
I am locked out of
my brother have locked my laptop harddisk how can i unlock even he have forget the password
I have a Hp 2133 mini notebook and just installed
Check once again the downloaded driver is the exact one for Ur NIC. Extract the downloaded driver in the other PC and copy the extracted content to the next and run the setup.exe file Make sure to Safely remove Ur pendrive.
My hp2133 is showing a black screen when ever i am
The screen is not getting power, the failure of the flexible cord to the lcd screen can also be a possibility. Also the power supply section could have failed thereby faulting the screen.
Hence you will need to check on all these sections of the mother board to confirm the issue.
Get help if technically not experienced.
Hp mini 2133 has no
hook up up external monitor to see if it is display or video adapter problem
I have a hp 2133
Not unless you can obtain a restore disk - but it's expensive. It's easier just to install a Linux like Mandriva
http://www2.mandriva.com/downloads/one/
Hp mini 2133 problem. blue
in this wise have u tried trying it with another memory module?
if not pls do try it so as to enable you ascertain what the problem is and after you might have done these and the problem still persist i will advice you to contact a laptop technician
