I own a Wd62530 Mitsubishi sixty-two inch television. I replaced the bulb last year after it blew out. While watching it the other day, it developed a purpleish-blue haze on the right side of the screen, and a blue vertical line across the bottom with the same haze. This happens after the T.v warms up. It is faint, but I am afraid it will get worse. Can someone tell me what this is? And how do I fix it?
Thank you for your help!
SOURCE: Mitsubishi WD62530 62 in. HDTV LCD displaying blue vertical lines
i just got the same tv today and the same thing happend to me but it happend with the satellite input and i did not have the blue vertical lines i just had a black screen and sound. i unplugged the hdmi cable that carried the signal to the tv and plugged it back in and i had a picture. hope this helps
SOURCE: Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
SOURCE: i have a vertical line across my screen from top
Vertical lines more likely to be caused by bad T-CON board, you need to check the connections between the T-CON board and the main logic board, it can possibly be the main logic board also.
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
