D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
Posted on Oct 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't install DWL-g122 on my imac intel core 2 duo 10.5.5
Installed drivers from disc but no setup info from disc
Anonymous
Level 3:
Genius:
  • Master 1,124 Answers
  • Posted on Oct 28, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1124
Questions
0
Helped
364909
Points
3197
If you're installing in your Imac You need a B1 or C1 revision for that USB dongle to work.
Imac os intel core 2 duo inverter
Pop in your OS X DVD and run a repair install or an archive and install.
4answers
Installing Leopard on my iMac
Yes you will have to clean the disc.
But if you have another mac hook it up to another mac, boot in firewire slave mode, and save thefiles.. (http://docs.info.apple.com/article.html?artnum=58583)
9helpful
2answers
Can't find driver for my d-link dwl g122 sothat i can install it my computer
You can download the driver for this adapter from this link, just select first the revision of your adapter and then after that select driver and the continue with the download for it so you can install it to your computer....
1helpful
IMac 24 intel no startup sound_black screen_but light is on
Try inserting the master (system) disc that came with it and hold down the "C" key while booting. If it comes on with the OS X installer, try disk utility to reset permissions, if that fails to solve it, start again and this time when you get the install disc up get to options and do archive and install. If that has no effect, get out your Apple Care ( you do have it don't you?) and take /send it to Apple.
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Who can help?
1. Find a program Pazifist , YOU HAVE 10 FREE USES. 2. Put Your installation OSX disc on drive 3. Extract .kext files onto your HDD, you'll find it inside Your Install DVD content with pazifist. 4. Find KextHelper 5. Install AppleHDA.kext with kext helper. 6. Enjoy!
1helpful
Found DWL G122 Driver
1.http://www.driverstock.com/download-D-Link-DWL-G122-driver/24-28-11275/index.html
2.http://www.driverstock.com/D-Link-DWL-G132-driver-download/24-28-11276/index.html
you got your driver just download it and installed it
1helpful
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Dwl g122 not connect with dwl g730ap
how to setup driver d-link DWL-G 122 for windows xp
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
