Is putting a 96 grand cherokee engine into a 1993 jeep cherokee possible.
SOURCE: life expentancy of 1996 grand jeep cherokee engine
If the engine doesnt smoke to much and if you dont have to add much oil between oil changes and you cant hear any unusal noises from the engine you should be able to run that car for many more miles. My dad has a 92 Jeep Cherokee and he over 300,000 miles on it and it still goes as long as you take care of it with regular oil changes you should have no problems
SOURCE: Will a 1996 Jeep Grand Cherokee 4.0L engine work
Computer hookup should be the same and physically it's the same engine. Only thing I can think of to check on is the engine mounts (not sure but there may have been a change there. Also, make sure you keep the same flywheel position in relation to the crankshaft and that both flywheels are identical in every way including tooth count.
Testimonial: "Thank you! that helps a bunch"
SOURCE: my 1993 grand cherokee jeep stall when i put it in
Check the crankshaft position sensor mine was doing the same thing also make sure there is nothing rubbing ontop it
