When printer boots up, an error code blue screen flashes "C2FE0100" and then screen turns white an the entire keyboard and on/off button blink about 4 times per second.
SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
SOURCE: C2FE0100 Error
Please check the link to HP support for you issue on your printer. The error fix is for "Turn power off, then on again" displaying on the control panel.
Please take the time to go through the troubleshooting steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&cc=uk&lc=en&dlc=en&product=1153494
Please rate if this help to fix your issue
SOURCE: Power button is blinking and Carriage is stalled
there are two cartridge one is the ink cartridge which can be found on the left side of the printer (in front)and the other one is the head cartridge that can be found on the right side if you will open the printer cover that is the carriage check it if the flip cover is lock properly then try to reinsert the head cartridge..
Testimonial: "I LOVE U MAN!! TNX FOR THE HELP! I HOPE I CAN BRING YOU PIE! OR SUMTIN' TNX SO MUCH ^_^"
SOURCE: HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer.
2) Plug the printer back in.
3) Immediately open the printer so you can see the ink cartridges.
4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again.
5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar).
6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary.
7) Close the printer back up.
8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button.
9) I pressed the power button once, and it shutdown.
10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
