Question about HP Photosmart Premium C309A All-In-One Printer
HP Premium C309 All-in-One Printer error message "C2FE0065"
I have an HP Premium C309 All-in-One Printer. When I turn the printer on, the screen goes blue with "C2FE0065" listed on the bottom. Then the screen goes black and all the lights start flashing. Is there anything I can do to fix it?
Posted by calwan441 on
Anonymous
    New Friend:
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Posted on Jan 24, 2010
Anonymous
    New Friend:
[After replacing ink catridges, my HP309a All-in-One printer is displaying C2FE0100, C2FE0029, C2FE002A error messages. The screen is dead white and some lights are blinking. I can't turn it off. [Thursday, October 14, 2010 12:12 AM] -- Asha R says:
Please take out all the ink cartridges from the printer.Then perform these steps on printer without the ink cartridges.
1. Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
2. Wait 30 seconds.
3. Plug in the power cable to All-in-One and also to wall outlet.
Now when printer displays message missing cartridges please reinsert them backThen power On the printer.
Okay, please reinsert the ink cartridges back
Okay, lets reset the printer once.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Oct 14, 2010
Hp c309 all in one, does not respond to the computer when scanning
Kindly unistall the drivers of Hp c309 and reinstall it again on ur computer..........
problem will solved......
Aug 31, 2011 | HP Photosmart Premium C309A All-In-One...
My Hp C309 photosmart premium printer does not print black, which i have just replaced and the alignment keeps failing. Please give me a solution for this. Thanks Fame
Most commonly people forget to take the protective tape off of the cartridge before installing it into the printer, so check that first.
Apr 12, 2011 | HP Photosmart Premium C309A All-In-One...
I have an HP Premium C309g All-in-One Printer. When I turn the printer on, the screen goes blue with "C2FE0065" listed on the bottom. Then the screen goes blank and all the lights start flashing....
The printer has a working mode and a standby mode. It could be going into the standby mode. Pressing the power button once, or sending it a print job will usually take it out of standby mode.
Most HP All in Ones will give a problem message on the screen. Your printer may have a more involved problem and you should go to the (hp.com) printers support page at HP. When you get the support page for that printer, type the error code in the search box.
If you are plugging it into the RJ45 Network connector (without a network) you may need to use the printer setup settings to tell it what type of connection to use ( USB or Network).
If the printer is connected to your telephone line and you are using a DSL internet connection you need to put a DSL filter on the telephone line going to the printer. The printer may be picking up DSL internet signals. Again the printer setup utility will ask you what type of connection you are using.
Mar 06, 2011 | Office Equipment & Supplies
Have a hp photosmart premium c309 and have changed the ink cartridge and the black ink is not printing well. All the other colors prink well
HP Photosmart Premium C309 not printing black
Got that problem also, Black would not print but dark grey would be printed ???
What i did and it worked was reset to factory settings, unpluging the printer for ± 25 seconds
holding 3 and # for and other 25 seconds went and after pitting power back on
then re-enterring your setting, all went fine
http://h30434.www3.hp.com/t5/Other-printing-questions/Photosmart-C309-suddenly-stopped-printing-black-ink-any-solution/m-p/495549#M30719
Hopping this will help others
Nov 10, 2010 | Office Equipment & Supplies
I have a HP Photosmart Premium C309 printer. How do I print directly on a CD? Is there a template available?
I checked the printer specs to be sure there was not some new technology I had never heard of out there, you never know. Your HP Photosmart Premium C309 printer does not support printing on CD/DVD disks, and as far as I know there is no printers that will.
What you need to print on a CD/DVD is a LightScribe CD/DVD burner. You will also have to buy special printable disks to use with the LightScribe burner.
Hope this helps
Oct 31, 2010 | Computers & Internet
Why does my hp c309 Photosmart Premium printer require two black ink cartridges? Can I use just one?
The Photo Black is pigment ink (last much longer than dye ink), while the Black is dye ink. Have alook here: http://www.earthboundlight.com/phototips/dye-pigment-metamerism.html for detail explanation
May 13, 2010 | HP Photosmart Premium C309A All-In-One...
Where is the pairing code on the HP photosmart premium C309
Page 70 of the printer's manual lists the code as 0000.
Here is a link to a PDF of the manual:
http://h10032.www1.hp.com/ctg/Manual/c01856408.pdf
Apr 22, 2010 | HP Photosmart Premium C309A All-In-One...
How to connect c309 printer to wireless PC
IT WOULD BE TOO LONG IF I TYPE IT IN
AND ALSO THERE ARE NO OF DIFFERENT WAYS
SO U CAN SIMPLY FOLLOW THIS LINK AND HOPE IT HELPS U
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631592&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=3979722
Mar 26, 2010 | HP Office Equipment & Supplies
HP Photosmart Premium C309A  All-In-One Printer Logo
3,648 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
