Dear Sir/Madam,
Please advise how we can block all outgoing calls from the Panasonic Set KX-T7730.
Best regards,
Taswer
SOURCE: Respected Sir/ Madam, Kindly help me. we are
you will need to dial *7102 9 phone number #
this will forward all your calls
external call forwarding needs to be enabled on your system and you really need ISDN lines
To forward calls ringing a group of phones - from a phone within the group dial
*7141 +group number - 9+phone number #
to cancel this dial *7141 +group number
SOURCE: I'm using Panasonic KX-T7730. and
In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
Carl
You have this posted in the wrong product category. Please select another category appropriate to the problem.
The beauty, and the curse, of Panasonic is that you can take a 20 year old phone and plug it into a new cabinet and it will work and vice versa. There are 16 different cabinet models in the U.S. alone that a 7730 phone will function in. While the programming is similar, it is not the same, so solving your restriction problem requires you to know which cabinet and what you have in mind.
In the newer systems, extension lock will block outgoing calls, so will assigning it a higher (7 or 8) class of service. A lockout from the System Manager's phone placed on an extension cannot be defeated and it still allows 911 calls.
Start with the manual for the phone system and look at TRS.
