Question about Panasonic KX-T7730 Corded Phone
I'm using Panasonic KX-T7730. and Panasonic Advanced Hybrid System KX-TES824BX . Please help me.I need to make security lock for outgoing calls ...
Posted by munna665 on
Carl Navarro
  • Panasonic Master
  • 2,460 Answers
In programming you can set up Forced account codes for Local, Toll, or All calls. The extension is flagged in program 605 or 2.1 of the system and the codes are put in 310 or 1.5. It's one of 2 ways you can do it, you can also change Class of Service on each phone to deny them access to certain numbers.
Keep in mind that this is programming for a TA-824 release 3.0. We know loop start CO lines and no ISDN or BRI. Your system may be different.
Carl
Posted on Nov 24, 2010
My phone is panasonic kx-t7730 white advanced system HYBRID SYSTEM it does not ring in the day time mode
it may be the battery for its memory be dead...if this is true the phone installer can straighten it out for you
Jan 18, 2014 | Panasonic Advanced Hybrid Kx-t7730 White...
Normally all thes phone call the standard ext 101 if they want to make a call but I am trying to set direct lines for some of them so they ll not have to call the standard whenever they need to call . ...
you have to do that in the pabx setting where by you set all out going calls to be calling direct but all incoming calls to be calling to the switchboard first so change the call restriction feature
May 18, 2011 | Panasonic KX-T7730 Corded Phone
How can I get a manual for Panasonic KX-T7730 ADVANCED Hybrid System?
http://www.wedophones.com/Manuals/Panasonic/KX-T%2077xx%20Manuals/KX-T%207720%20User%20Guide%201921wa.pdf
this manual covers the phone itself but you should look for the manual for your phone SYSTEM (box on the wall that runs all yours phones)
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
I want user manual for panasonic kx-t7730
I need on to, for Panasonic KX-T7730 Advanced Hybrid System.
Panasonic KX-T7730 CORDED PHONE
my telephone is lock forget pasword
Oct 14, 2008 | Panasonic KX-T7730 Corded Phone
Programming numbers into telephone
to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
<pick up the receiver>
<the number you want to have as speed dial>
<the number you want to dial>
<press the square shaped key next to 0 and 9>
<wait for dial tone to return>
<hang up>
To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
For example
<pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
This will mean that when you press the square key and 1, it will dial 555555555
Oct 03, 2007 | Panasonic KX-T7730 Corded Phone
Calling out
Here is the link to the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF Page 7 - locking your extension should help you out Please ask again if you need more help :)
Feb 23, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
427 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
martin hogg
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
