You probably have a front loading washer. This is something you have to get use to. If the water level is set to high, thatās all you can do. It should be good enough just hard to understand. Clothes donāt need to be saturated in water like a top loader. Front loaders are all about saving water and cleaning just as well.
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Scott, Believe me, if the water level were ever several inches above the glass, you'd know about it 'cause it would flood your laundry room. Seriously. See? That rubber door boot/seal is not water tight (like a submarine) when the door is closed and locked, it's water "resistant".
Front loaders often appear as though the level is low, but they are designed this way. The clothing actually tumbles through the water as opposed to soaking in water like a top loader.
All of that to say that you have nothing to be concerned about. Your water level is fine.
SG
p.s. If your water level switch had failed, as you suspected, the water level would be too high and leak out the door.
not so much hte switch , but perhaps the hose that attaches teh tub to the switch, usually it rubs a gainstrear of machine and gets a hole in it, look to the hose first
the parts that control the water level is the water level switch.it's with a hose connected to tub and the water level switch. check if your hose is still ok, or your water level switch deffective
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean. These washers normally get the clothes almost dry.
