SOURCE: minolta di 251
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
SOURCE: MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
SOURCE: konica minolta DI 750 error
Hi this error code is an issue with the fuser unit it could be the thermistors lamps ect you will need to check the parts and replace worn or end of life parts if you hold down the utility key and power off the machine then power back on the machine holding the utility key wait about 39 seconds then take your finger of the utility key on the screen trouble reset will appear press the screen power off the machine then back on again this will reset the code
SOURCE: minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
