SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
SOURCE: HP Officejet 5510 error "Remove & check color cartridge
When the error message popped up on my computer there was an option for tech support. I clicked on that. I went to the HP website. then found my way to tech support. I clicked on what printer I had and it set me up with a chat session.
The person helped me and it is now fixed.
I pressed Setup then 6 then okay
then after that was done I pressed setup then 6 then 2 and okay
now it's fixed...
I hope that this might have helped!
SOURCE: How to check ink level for a hp 1210 printer /vista
SOURCE: how do I check the ink level of my HP Officejet 6300 series?
only wy to check levels is to install the software that is part of the printer it will give you ink levels as they go down
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP
integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901,
92-98....currently offered at Costco or Frys today) or if you buy a
remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP
has a smart chip embedded within the nozzle plate at base of ink cartridge
which counts the drops and then registers as empty).....so you'll just need to
live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and
similar while you are using these types of aftermarket supplies. The first
video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem" etc.) typically indicates the internal micro-electronics
of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire
runs at rear and lower side of the ink cartridge are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on all models which use HP 901 cartridges. Refer to
Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer
Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts -
Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers
Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500
J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care
Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
When you get an HP
remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print
Low Ink Warnings:
HP Officejet J4500
HP
901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print
of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire
Low Ink Warnings:
HP Officejet J4500
HP
