Vibration is present everytime when starting out from a stop, or by putting truck in neutral and slowly give it gas.
If the vibration increases as you accelerate and change through the gears you could possibly have a universal joint on half shaft that is worn beyond its limits.If it only vibrates as a the motor increases the rpms it could be that your harmonic balancer this damaged all worn out.There is another possibility and that is that you have a damaged tyre that goes out of balance very quickly.
Regards
SOURCE: 2002 Dodge Grand Caravan, 69k miles, vibration at idle in D
check the motor motor mounts for movement,
watch how far engine rocks forward or back with it running and foot on brake
SOURCE: 2000 Dodge Dakota vibration while driving
sound like the u-joints in the driveshaft. Lay under the truck and where the u-joints are try moving the driveshaft up and down. If it moves then the u-joints are bed. This will cause a tremendous vibration under a load and the faster it spins it will smooth out.
Testimonial: "That's pretty much what I thought. Just trying to get some feedback about what I already suspected."
SOURCE: 2003 dodge neon motor mounts are causing vibration at accelerated
there is a motor mount that attaches frum the passenger side wheel to the tming cover. this is the mount that usually goes bad. you have to remove the wheel to see the torx bolt at the wheel well. than there are bolts on the other side of the wheel well. after you get those the ones at the motor have to be removed. you will have to place a jack under the oil pan use a piece of wood with the jack. you also have to take the top mount of first. thats pretty easy to replace.
SOURCE: 2002 Dodge Grand Caravan, 69k miles, vibration at idle in D and R
if what your feeling is not an engine miss,
then it will be a motor mount,best chances are the front center one,,
or top trans mount
SOURCE: Sprinter vibration
Same thing with one of the customers.. It's normal nowadays with auto trans vehicles, since the got ect-i's.
