I just got done re-working a Samsung that had the same problem. You can either buy a set of RCA jack audio cables and cut them to a 6" length and remove the jack in the set and solder the cables on to the board, or you can buy a new board at about $150.00. You will have those two cable hanging out the side but its a heck of alot cheaper than buying a board. That is if your handy with a soldering iron and have patience.
SOURCE: samsung un55b6000 hdmi input 1
Unplug the unit from the outlet for 30 minutes and then re-plug it and then check if the symptoms still the same. If so, this is an indication of faulty I/O circuitry and video processor in the main board. This board is repairable only at the service center because the parts are surface mounted and quite sensitive. If you are going to DIY, I would advice you to replaced the entire mainboard rather than troubleshoot it because the cost is almost the same. Obtain the board from your local Samsung service center or online. Check the actual part no. of the mainboard on the white sticker on the board itself and then search it online.
Also, check if your unit is still under warranty/extended warranty period, if so avail it because the manufacturer will fix it for free. Opening the back cover will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Do you have a mechanically broken jack on the component input, or do you get nothing or a faulty picture when you try to select it? Does the sound connection for this input work?
I have a mechanically broken jack. Now I cannot listen to the home theater system off of the TV. What solutions do I have?
Hi Paul, the jack is broken on the back of the tv. There is no sound if I try using my home theater system. The tv works perfect on its own. No screen problems or sound concerns, just that when I want to watch a movie using my led tv and want to use the home theater, it doesn't work anymore. Just the speakers on the tv. I hope I'm making sense
