I want to transfer my pictures from internal memory of S2550 to sd card. cant find anything on menu which says copy.
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: internal memory photos download to sd card
Press the menu and look for the utilities section on the camera. There should be a copy from memory to SD.
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
SOURCE: pix transfer from internal to card
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
