I have a kodak dx6490. Recently I have noticed that the flash is not working - which isn't a problem...
(More)
I have a kodak dx6490. Recently I have noticed that the flash is not working - which isn't a problem unless I am trying to take photographs inside. Can you tell me how easy it is to repair/replace the flash? Thanks
I swapped out batteries with the power still on. Now it won't operate properly. The power won't...
(More)
I swapped out batteries with the power still on. Now it won't operate properly. The power won't turn off unless I remove the battery and then the lens won't retract. I turn it back on and the lens retracts and then reopens but I can't take pictures.
Ho lo stesso problema. Sulla guida non esiste nulla. Alla Kodak non sanno risolverlo. Ho buttato i...
(More)
Ho lo stesso problema. Sulla guida non esiste nulla. Alla Kodak non sanno risolverlo. Ho buttato i soldi per acquistare un prodotto (DX6490) che senza motivo ha dato questo messaggio!!!!!
My kodak easy share DX6490 camera fell down and I think it got crack in side the lence part. The...
(More)
My kodak easy share DX6490 camera fell down and I think it got crack in side the lence part. The camera is working but the zooming part not get work. The screen is also not get worked. I need the solution. Either can I repair my camera or Where I can get my camera repaired. What is problem in my camera. Thank you for your help.
Doesn't focus properly and green box showing in viewfinder around focus area for EasyShareDX6490 ...
(More)
Wondering if it is worth fixing....and how long it will take?
These are some of the problems I have encountered over the years. It mainly relates to Fuji digital compacts but could just as easily relate to any...
written by daveward712
This tip is for Kodak V803 cameras that will take pictures fine but you can only be able to see them if you download them onto a PC. A replacement...
written by sharcnet
#1: Remove the batteries from the camera, wait a few
minutes. Put a fresh set of batteries back in and turn the camera on. #2: Remove the batteries,...
written by dileep007
I had this problem for a while and after sending it into the shop I was told that it was because of a small piece of sand that had been lodged between...
written by jessemphotos
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the...
written by ginko
When the lens will not retract and camera is not functional (no picture on
display, and does not shoot) , and you already tried replacing
batteries...
written by ginko
This article describes how to modify an ordinary webcam to capture images in the near infrared wavelength. All that is needed are two very small...
by wikihow
CamerasAndParts.Com Specializes in the Service / Rep... Read More
CamerasAndParts.Com Specializes in the Service / Repair of Canon PowerShot Digital Cameras / Canon Digital Camcorders! We also offer a Huge Selection of both New / Used Genuine Canon Parts! Let us do it for you, Our Complete Service / Repair Packages are available for all Canon Powershot Cameras and the value is simply unbeatable! Let us help :)
Worldwide AFFORDABLE digital camera repair & par... Read More
Worldwide AFFORDABLE digital camera repair & parts.
We can repair most broken lenses for only about $85! We also have amazing prices for LCD repair, OR you can buy the part and install it yourself for even less!
Check out our site for more information!
