Model: KUDS30IVBL3
SOURCE: my dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
SOURCE: dishwasher will not drain completely
dishwasher will not drain.kenmore model.
I have taken it apart can not figure our how to take out last plastic part a bowl shaped black plastic.
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
SOURCE: Kenmore Dish Washer does not drain completely
The dishwasher is actually located in a rental in another state. My tenant had a plummer friend correct the problem. I don't know what he did.
SOURCE: the dish washer will not drain. There is water in
there is probably astuck peice of glas in the propeller. manually drain unit. take a torc screwdriver and remove screw in bottom of unit. you are removing a piece that looks like a plastic cover. now carefully spin the propeller and take out what is stuck ,put back screw then hit cancell and drain. that should do it. let me know if this was helpful
