We Have FS-1118MFP
I'm trying to use Network port..
The printer already have IP address,Subnet mask & gateway ,same in the workstation set-up . I already turn off the DHCP of it.
But still I cannot find the printer...??
Please help me to set-up printer in my winXp computer???
gracymine,
The copier and the workstation should have IP addresses from the same LAN class.
Open any internet browser and try to see the printer's webpage - Command Center by typing the printer's IP address.
If you see it = OK if no then something is wrong with the network ...
If you are using a router/hub check if you have a green light for the printer port at the router/hub and at the printer - ussualy a green light indicate OK
If the cables and the rest of the network hardware is OK do a ping from your computer to the printer.
In windows XP: Start->Run-> type cmd
then: ping xxxx.xxxx.xxxx.xxxx
whre xxx = printer IP address
you should see a replay if everything is OK
A very simple check is to bypass the whole network infrastructure (which may be at fault) by connecting the PC or a laptop direct to the printer using a cross-over network cable. Give a static IP to the printer and a static IP to the computer. from the computer you shoould see the printer webpage (open any internet browser and typ the printer's IP Address)
Sometimes for security reasons routers have ON some filters - check any firewals about MAC / IP filters or ports. To print using the network printer you need to let open port 9100.
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
First find
out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet
Service Provider ). According to above addresses, you have to complete the network
settings of your printer by mentioning the different IP address .
To find out the above mentioned
addresses, first open the control panel -> network connections -> local area
connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR
Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as
mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the
gateway may be 192.168.0.1 Or any number. And the subnet mask may be
XYY.XYY.XYY.0.
According
to your ISP addresses you have to complete the network settings of your
printer. First press the additional functions -> system settings ->
network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ). According to above addresses, you have to complete the networksettings of your printer by mentioning the different IP address .
To find out the above mentionedaddresses first open the control panel -> network connections -> local areaconnction -> properties -> Internet Protocol Version 4(TCP/IPV4) ORInternet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection asmentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , thegateway may be 192.168.0.1 Or any number. And the subnet mask may beXYY.XYY.XYY.0.
Accordingto your ISP addresses you have to complete the network settings of yourprinter. First press the additional functions -> system settings ->network settings -> TCP/IP settings -> fill up the addresses as follows.
Hurray ! the problem about your networkconnction with the printer to your computer will be automatically solved.
