Sylvania 6620LG 20 in. EDTV-Ready LCD Television Logo
Posted on Oct 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HDTV Is it possible to get a full picture on this set in HDTV? I can only get a reduced size picture even on reugular cable channels also.
Mark Hammonds
Level 2:
  • Expert 61 Answers
  • Posted on Nov 19, 2008
Mark Hammonds
Expert
Level 2:
Answers
61
Questions
Helped
16112
Points
121
Some shows are only brodcast in one format if not try the pic. size or aspect yu may have to go in to the menu browse through there for picture preferences
I can not get a full screen picture on my Toshiba Cyclone ABX TV
Some sets do not have full 16X9 and also some sets using a cable or sat box will determine the size of the picture and not the set.
Check and read owner manual for features and if cable/sat has variable or fixed (usually is different channel to channel) format for this.
1helpful
My sanyo hdtv plasma won't show the whole picture but it worked fine yesterday
Hi my name is Roety,
I can help you with your issue ,
There are a few buttons to adjust the picture size on different make TVs and even on the Cable/Satellite remotes .
1.Format
2.Aspect
3.Size
4.Zoom
5.Wide
6.#
First look on the TV remote, set it to Full ,Fill or Just or 16 x 9 (whichever your model uses) Samsung uses the P size button ,
Then on the cable/dish Box remote stretch (not zoom) is usually best.
On the box remote set the output resolution to 1080i only
And use 16x9 when if offers a choice.
Cable remotes use the # key as a zoom/size button.
Due to the fact there are 16 size/Formats available (3 or 4 being transmitted now). you may have to hit the zoom/stretch button on some HD channels.
But with these settings the picture will mostly stay full and help you avoid image burn from the edges being not on the edge.
Stretch will fill the screen and allow you to read the bottom.
Make sure you are on the correct input, sometimes TVs are connected on multiple inputs
(not necessary, only the HD input is needed)
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
7helpful
2answers
The whole picture does not show on the screen; faces on the edge are cut off
It's one or two problems. It depends on if you're using a cable box. First try to see if your aspect ratio is on full using the JVC remote. Just Press the Aspect button. Then if it's on full and this doesn't correct the problem it may be your cable box. If it's time Warner go into the settings by pressing the settings button on the remote twice I believe tehn go to display and select the select and check each option picture size (change to normal if you have a 4:3 t.v. or stretch if you have a 16:9 (wide screen T.V.) Then go to aspect ratio and select again eih 4:3 or 16:9. If your have a hdtv cable box select output resolution and make sure there is a bulllet next to each setting for 480i, 480p, 720p and 1080i. Then exit out of the cable settings and your picture should be ok. Now if you have the hdtv package keep in mind it is normal to have the black side bars on each side of the picture only if your watching one ofthe high definition channel network that is not actual being broadcast in hdtv or recorded in hdtv.
2helpful
42' hd tv has stretched picture makes people look fat
you have a few settings to size the picture as best as it can be sized.
format, aspect and size . try setting the TV (remote) format to full, fill or just.TV size to 16x9.
If also using a cable/satelitte remote set it to 16x9 size, stretch format/aspect and 1080i output. then just press the # key on cable remotes or format key on Sat remotes to size it best on each channel.
with 16 formats available, today's TVs are doing their best to keep up.
hope this helps
Eric
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
HDTV
Usually they can do that, like the sides will come in a little bit. I have HD on my 50 inch plasma Samsung, and we have Time Warner Cable, but not all of our channels are like that. If all of them are like that for you, then you should go to your menu and settings to look for zoom. But if they all aren't like that and only some, then that's how the channels are.
1helpful
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
3helpful
2answers
Sony Bravia - Picture in ZOOm Mode
I corrected mine by adjusting my cable settings. It had been set to "zoom" / "wide" mode. I reset to "normal" and now channels look fine again.
1helpful
2answers
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
