Hello, i have DELL XPS M1330 and i need the BIOS Master password whereas my Express service TAG# is 366-351-363-19 and Service TAG #GTVM43J please help
SOURCE: Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
SOURCE: led backlight on display for m1330 xps dell
This model laptop uses a CCFL lamp for the backlight, it does not use LEDs for backlighting.
The CCFL lamp is attached to an inverter which supplies high voltage to this lamp.
For details on how to install and or replace CCFL lamps go to
www.lcdparts.net for information and parts.
I assume you are not replacing the whole LCD screen.
There is no generic password.
If you are the original owner or if you know who the original owner is Dell can help you to remove the password for free.
Otherwise a tech will need to remove it and they usually charge $50-100 for something like that.
I have one dell xps m1330 laptop. These are few days my laptop has getting some problems. When I on my laptop it will appear blue screen. I can’t see anything. I had change hard disk and Ram. Some times I have switched on my laptop that time ask press F1 or F2 or F5. When I press F1 it will go to window. What is actual problem? Would you help me?
Hello Sir I can help you .Send me service tag which u can see on the bottom cover or turn on laptop u will see on screen hash code like this XXXXXXX-595B or D35B, A95B or 2A7B send me complete .i will send You MASTER PASSWORD Thanks.
