Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
