HI. thanks for the question. you have a blown fuse ,inside the washer. remove the front panel. on the left ,you will find a small glass fuse .check that. if its failed you will be able to see, that the small metal strip inside the fuse is broken , if so replace the fuse. thanks the appliance doc . please rate my answer.
I have the same problem: the washer doesn't do anything!
Which front panel do you mean? The slanted panel under the dryer? Or the panel with the knobs that you set to start the washer/dryer?
And is the fuse on the left? There are two smallish things that insert into the machine? (this is in the slanted panel under the dryer).
Much appreciated and thanks.
Which
And
Ok. I've opened the front panel of the washing machine.
Saw the fuse and it appears to be ok.
What else could this be please?
Thanks for your help.
