Re: Broken spring on Zanussi dw908 dishwasher door
Hi. thanks for the question. remove the bottom kick plate. 4 screws at the bottom. 1 spring each side . replace both springs . thanks the appliance doc
Prior answer by a trusted expert, Andrew Taylor, on FIXYA is no longer available at the link he posted. (https://www.fixya.com/support/t27007981-omepga_dw908_manual)
Unsure if the following free manual is for your dishwasher or not, as it has a brand name of Zanussi. You can add information using the Comment menu to reply or respond here. In searching the internet, using https://www.google.com, several searches suggested people could not locate an actual instruction manual on the manufacturer web site years ago.
If the door won't stay shut the issue is with the door catch not the door springs, But if you want to know where the door springs are you need to remove the outer cabinet of the dishwasher and you will see them on the lower sides.
Check it is draining properly, if it is then the water level sensor is blocked, usually a small pipe running from the sump up the side of the machine to an air pressure switch, often gets blocked where it joins the plastic sump.
You should have one at the bottom corners of the door. Pull the dishwasher out about a foot and you should be able to see the broken spring and the hooks it connects to. Screws under the counter top hold the dishwasher in.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
You need to remove both side panels to allow you to gain access to door counterbalance springs. Visually see what is broken or come off of allignment then rectify.
