Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
The door spring is broken and the door falls open
The door spring is broken or disengaged as the door falls open with a bang. The actual model number is KUDS01FLSS6.
Posted by houfranks on
bosch guru
  • 457 Answers
There is springs on left and right side held by string and spring. one is broken.letme know how it turned out.
Posted on Feb 26, 2010
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door falls open, no restraints
Yes, I've fixed a few, and was unable to fix a few. You may need to remove the whole cover of the dishwasher to get to the insides. You should find either the springs are broken on both sides of the bottom of the door, or even more likely, the plastic parts between the springs and the body or the door have broken. The parts can be ordered from "Sears Parts" on the inter-net. You will need to provide the model number to look them up.
Be blessed.
May 21, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Broken sprocket coupler
Could be. Yet you may only need to adjust the springs and not replace them.. In case you have roll up/ sectional garage door, it should be quite easy you need to release the traveler from the rail so you can open and close the door manually/by hand then, while open the door on the knee level leave the door. If it falls down the springs need adjustment.
In general the door should stay at the same position on every stage it is while pulling it up and down.
If the door falls/ closes down not enough tension on springs, if door opens up too much tension on springs. If door acts funny.like close when close to the floor and jump up when its futher more open, it means that you don't have the matching springs for the weight of your garage.
Oct 21, 2012 | Sears Craftsman LiftMaster Chamberlain...
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door spring rope broke on door , door falls when opened like to fix it need part and diagram of unit
http://www.bosch-eshop.com - enter the correct model number: SHE43P05UC in the search box on the right side, select which dishwasher you have from the results list. Click on the number of the part you need, it should show the manuf. par number on bottom.
or go to http://www.searspartsdirect.com and check there.
Once you get the manufacturer's part numbers - go to http://www.repairclinic.com - they have pictures of most parts.
Vlad,
First Choice Appliance, Sacramento
Jul 06, 2012 | Bosch Dishwashers
Almost at the end of the wash cycle the door falls open, not just unlock but actually fall right open
on most all dishwashers on the very bottom on each side is a pulley like system with two springs one for each side along with a small piece of rope or cord that stretches the spring open and closed as you open and close the door if your door is falling opened most likely you would have to replace these lower pulleys as well as the springs what is the model number of your machine if you have any further questions please message me back and thanks again for using fixya please also note this fix is on most all dishwashers i am currently not able to see your model number so i cannot specify exactly for your machine Thanks again Rick
Jan 10, 2011 | Candy 17 in. CS455 Built-in Dishwasher
I have an Indesit DV62WHUK dishwasher and the last night the door made a banging sound when it was opened and now it won't close and will fall back under it's own weight. I suspect either a spring, spring...
There is a plastic unit behind the door handle which houses a spring under tension. This latches the door closed and makes the electrical connection to allow the machine to work properly. You need to buy a new unit (£15) which is a bit fiddly to reach but easy to fit (2 screws)
Dec 02, 2010 | Indesit 23 in. DV62 IX Built-in Dishwasher
Broken door spring?
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Dec 14, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
1,708 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
