Plastic stips with spigots are screwed to the 'integrated door panel'. Unfortunately the door panel keeps falling off!
I have replaced the plastic fitting strips 4812 404 48611 at least 3 times but after a short time the panel falls off again. Clearly I am doing something wrong here. Just how do you fit this panel?
Thanks,
R.Wheeler
[email protected]
SOURCE: How do I change the plastic panel on the door?
You may not have to, go to www.applianceart.com to see many options that go over your current panel. They also have stainelss replacement panels. The only dishwashers that have panels that you can replace are "frame" dishwashers. If you have one of these, there will be two screws on the side of the door that, when unscrewed, release one side of the frame allowing you to slide the panel in and out. If you dishwasher has metal that wraps around the side, you may want to trya vinyl and a stainless steel foil option that wraps over your door around the sides. Also available at applianceart.com
SOURCE: My Whirlpool Quiet Partner 2
Yes you can but you will need the last few digits in your model number . Off the machine itself .
SOURCE: I need to replace the plastic panel at the top of
Having looked at the parts site and going by the description there are 3 possibilities - panel, grip and handle.
Please check if this is the front top panel of your dishwasher.
In that case the panel is the whole top part that is screwed to the door frame, the grip is the bit inside the recess that has the handle inside it. Please confirm if this gives you an idea which part you are referring to.
SOURCE: Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
I am not sure about which parts are required to fit the decor door but I do know of an easier option to change the look of your appliances. www.applianceart.com These guys have so many options and even stainless steel.
SOURCE: hope you can help ive gone and lost the
I do not have instructions for your particular question but I do have an alternative. Appliance Art offers a wide variety of designs for your dishwasher and fridge. Their products are so easy to install and remove. They also have real stainless and faux stainless options. Worth checking out. www.applianceart.com
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
