My turntable seems to only being playing through one speaker - is it easy to change the phono lead coming out of the 1210 if that is the likely problem?
In my business I work on a lot of turntables. Specifically, Memorex, Anders Nicholson, Innovative Technology and Emerson. 99% of the time when I only have sound coming out of one channel it is due to a broken cartridge. If you look at the tone arm head from underneath you will see a rubber fork that the needle arm sits in. There are usually 2 ceramic cartridges attached to the rubber fork. Those transmit the sounds from the needle. If one of those brakes then that channel will not transmit any sound.
SOURCE: 1210 mk2 only playing through left speaker
If you have done some soldiering and have a steady hand, it's not difficult. If you are not sure, you could destroy that little circuit board that the lead runs to, and technics had discontinued production of that part. I'd say get it done by a pro with experience.
These guys are top notch:
http://www.repairnyc.com/
Hope this helps.
SOURCE: hum when turntable connected to phono sockets on amp
this turntable absolutely came with a ground wire that must connect to the gnd connection on the amp. maybe it got torn off or something but there should be clues on the back of the turntable as to what happened to it.
once the lead is found it must be connected to the amp gnd connect to get rid of the hum. this might require someone with soldering skilz or what have you in order rig up a new wire.
a tech might have to remove the bottom and solder in a new wire if it is cut or ripped off at the housing. This is common as people forget to unhook the gnd wire from the amp when moving things around.
SOURCE: 1210 mk5g tone arm pin stuck
Hey raz, i've just taken apart and put back together my turn table trying to cure the same problem. I DIDN'T NEED TO!!!!
number 1) i think the tone arm is a sealed unit so far as i can gather so if the spring is broken you need a new tone arm. however. Get a cotton swab, soak in malt vinegar and use this to gently push the faulty contact in. The idea behind this is to get vinegar around the contact shaft. This should dislodge the dirt and release the contact.
