FixYa.com
Sherwood RX-4103 2 Channels Receiver
All Products > Sherwood > Receivers
Problems with Sherwood RX-4103 2 Channels Receiver?
Troubleshooting and Support
Solved Problems for Sherwood RX-4103 2 Channels Receiver RSS Feed Post a New Problem
sherwood rx4103
my receiver was working fine but now its on standby and when i press the power it turns on and then it cuts right back...
1 Solution
Tone Direct Problems
I just moved into a dorm room and for the first time I've started having problems with this unit. The tone direct keeps...
1 Solution
Left channel out
I have a sherwood 4103 receiver and my left channel is out. Not a speaker issue, or input issue as headphones, and cd,...
2 Solutions
NAD 712 Stereo Receiver display
The LCD display on my NAD 712 receiver quit working. The problem has been isolated to the backlighting for the dispalay...
1 Solution
reciever not working
one time i turn on so loud the fuse blownoff.i replace the fuse but every time i turn it on the display said...
1 Solution
How many speakers total can I connect to...
How many speakers total can I connect to my receiver?
1 Solution
My ICOM IC-PCR1000 has no receive audio in...
My ICOM IC-PCR1000 has no receive audio in USB, LSB and CW modes. AM and FM modes are fine, what can i do?
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Sherwood RX-4103 2 Channels Receiver RSS Feed Post a New Problem
sherwood 4105 receiver wont let me preset...
My receiver was working fine, i turned it on and all my preset stations were gone. when tried to preset them again, it...
Post a Solution
remote
I don't remember if my 4103 even came with a remote. I sure can't find one, and I can't seem to program a universal for...
Post a Solution
Sherwood RX-4103 won't power up.
Receiver worked fine last time I used it. Now when I push the power button, the standby light goes out, display does not...
Post a Solution
can I use my rx 4103 as a preamp with a...
There is no preamp out on the reciever. Can I use the tape out to go to the amp.
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeReceiver
Number of Channels2 Channels
Stereo Mode Power105 Watt @ 8 ohm, 40 Hz - 20 kHz, THD: 0.9%
THX CertificationNo
Inputs / Outputs
Rear Input ConnectorsRCA (2 Audio Channels) x 4
Rear Output ConnectorsRCA (2 Audio Channels) x 2
Front A/V ConnectionsHeadphones x 1
Convenience
Tuner Presets30 Channels
Tone ControlsBass & Treble
Speaker Impedance8 ohm · 16 Ohm
Speaker SelectionA+B or A/B
Remote Control
DesignKeypad
Illuminated RemoteNon-Illuminated
Dimensions
Depth13 in.
Height5 in.
Width17.4 in.
Weight18.0 lb.
Sherwood Contact Information
Main support number(562) 741-0960 (Ext. 115)
Support FAX(562) 741-0968
Email supporteugene@sherwoodamerica.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
