FixYa.com
Technics SL-1200MK2 Turntable
All Products > Technics > Turntables
Problems with Technics SL-1200MK2 Turntable?
Troubleshooting and Support
Solved Problems for Technics SL-1200MK2 Turntable RSS Feed Post a New Problem
Technics 1210 feedback/grounding problem
at mid to high volumes when the needle is on the record and u touch or tap the deck u can hear the tap or touch coming...
1 Solution
technic 12000
I am getting no sound out of the left hand side of my technic1200 mk 11 deck. I have changed the leads and this made no...
1 Solution
Technics Turntables
Hi my name is Vick, and i bought a used 1210 technics turntable, my problem is the PITCH CONTROL its not right, it...
1 Solution
power problem
I was using my 1200 for about 4 hrs like i do in any event a suddenly the leds on the on off went off, but i turned it...
1 Solution
technics 1200
i just aquired some technics 1200's when turning them on the light came on for a second then went off...i now cant get...
1 Solution
Technics SL 1600 MK2
I replaced the servo belt under the tonarm and the tonarm does not come anymore to the end of the LP; it plays the LP...
1 Solution
power switch woes
the power switch on my turntable is broken..the black part ontop that rotates has come off and the record player will...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Drive TypeDirect
Pitch Range+/- 8 %
Pitch ControlWith Pitch Control
Other Features
Speed Settings45 RPM
Dimensions
Depth14.17 in.
Height6.3 in.
Width17.84 in.
Weight27.6 lb.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
