20 Most Recent Technics SA-DX1040 Receiver Questions & Answers
double check there isn't a piece of wire that has broken off the speaker cables and is shorting two of the speaker terminals together. The unit needs to be turned off and unplugged for a minute to reset the protection circuitry. If this doesn't fix it, there's likely an internal failure.
Technics... | Answered on Dec 24, 2014
It might be REM0080B $21.72 at Panasonic.
They're also available at anumber of online suppliers. Google "rem0080b fan"
Support: 1-800-211-PANA (7262) could verify the part number.
Technics... | Answered on Feb 20, 2013
Check the bottom of the receiver. there should be an access panel under the amp ic section. Look at the connections on the amp ic's and voltage regulators that are next to them. If you see any round rings or loose looking connections, it could just need to be resoldered. This is pretty common on these receivers.
Technics... | Answered on Jan 09, 2013
There are 2 major possibilities and since you didn't say if the sound comes back here's the general split.
1. The power amp section could be having problems and/or protection circuits are kicking in. In this case repair of the amp will be needed.
2. There is a bad connection somewhere making the audio path go bad. In this case a good can of contact cleaner applied to all switches and controls may help. If not, the bad connection may be internal. If tapping (or rapping) on the unit makes it come back, there's probably a bad internal connection.
If letting the unit cool down brings back the sound, its the power amp section.
Technics... | Answered on Dec 19, 2012
Yes, it connects directly to your TV with a choice of cables - check their site for a description of your options there.  And if you have a wireless network (router) it will connect to the internet through that, so you don't need to have a cable running back to where your computer is.
Technics... | Answered on Apr 16, 2011
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Technics... | Answered on Feb 11, 2011
yes, there is such. There is a fuse on each channel. Get a screw driver, disassemble the unit, and check the fuse on the channel.
If the fuse is intact, then it means a capacitor or diode may have become defective. Use a meter to detect the bad component on the non working channel, the will reveal the problem.
If you have any more questions, please let me know.
Good luck.
Technics... | Answered on Jan 11, 2011
Hi, Have got and still use a Technics SA-GX910 Dolby Amp. It had an overheating problem too due to Air temp and power drain etc and the internal fan only engaged at certain volume level. Overheating was overcome by adding another internal fan.
Your unit however might need a bit more of a fix-me-up or throw it away
Technics... | Answered on Oct 09, 2010
Any self-amplified sub will do.
Technics... | Answered on Aug 16, 2010
Don't worry I will help you.
First
You must on your Roku player & Your laptop.
Play netflix again then its says enter code .
Follow these steps
1. Sign in to your netflix account on your pc then you see right hand on the top of side my account & help click there.
Scroll down & you got these options on the page.
WATCHING INSTANTLY ON YOUR TV OR COMPUTER
* Activate a Netflix ready device
then click here you get code. You should paste this code to your roku netflix.
Technics... | Answered on Jun 09, 2010
1.Check the audio input terminals.
2.Try a different set of speaker.
3.Replace your left & right amp-if out puts..
Technics... | Answered on Mar 07, 2010
You have to manually select digital input on the receiver.
Technics... | Answered on Aug 30, 2008
Fixya does not sell Technics parts.
Technics Audio... | Answered on Sep 17, 2019
Technics SA-DX1040 Receiver Logo
23 questions posted
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Technics Audio Players & Recorders
Most Popular Question
receiver displays overload all time when
  • Audio Players & Recorders
