I keep losing this page so I hope you get this one. When I turned off the TV last night, everything was normal. This AM when I used the remote to turn it on, the green "ON" light on the front panel came on but nothing happened. There was NO blue screen. The screen was just blank as if it were not turned on. I could not get the green light to turn to amber (OFF) until I unplugged the unit. I tried the "Display" button and nothing happened. (green light was on). I have Comcast Cable which I rebooted several times, but nothing. I am sure it is the TV. Any ideas? Thanks
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: screen stays blank after turning it on.
Hello, The blinking pattern you're observing is a result of a heavy current load on the power supply. The power supply could be defective but more than likely the scan or sustain boards have a direct short on them causing the power supply to shut down and display the error. A technician will be able to determine where the load is coming from and replace the appropriate board or component. I hope this helps you. Joe Weibel CustomElectronics.Org
SOURCE: MAxent plasma will not turn on
open the back and reseat the LVDS cable(looks kinda like a computer data cable)...also check your other circuit board connectors..literally unplug the connectors..and reseat them...Question...is the set working now?...or is it not coming on?
SOURCE: TV gettin power...but no pic and no sound
I am Having the same problem as PScott. I will open my TV this weekend wil a friend who is a electrical technitian. We hope that ther is any schematics inside the TV though..
SOURCE: Loss of Color
Have two basic colors blue and yellow or green as the combination all other colors are grey. What are my options...The Boston Celtics Colors are Grey. All others colors are good.
SOURCE: the TV does not respond to the remote control nor the buttons in the front panel
i am haveng the same problem p58h10nja
no green light no power at all
