Power up the printer and the display says initializing. There seems to be some cycling of the scanner then an error shows up for a few seconds then the whole thing starts over again.
See the manual here
http://downloads.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-2335dn_user's%20guide_en-us.pdf
It has trouble shooting and problem solving sections.
SOURCE: Dell 922 printer giving error code 1200
I get error 1200 and print carrier stall. The carrier moves fine when I turn it on, in fact it slams to the right! Will not print at all!
SOURCE: Error message 004-321?
I HAD the same problem...a couple of posts up/down, someone suggest to re-align the film roll on the Drum. This worked for me. There are two wheels on the outer-side of the film reel (the film reel is one of two reels on the main top drum). Take out the drum, not the green reel, but the other one. Check both ends and you can se/feel two little silver metal wheels (again, at the ends). Roll the film around with your fingers until it is aligned evenly with the wheels. The metal on the wheels should not be showing at all, they should both be covered by the film reel. Replace the drum and cross your fingers. This worked for me...I'm sure a NEW drum would fix the problem, as well.
SOURCE: dell 5200M laser printer
there is a flag in the output bin that lets the printer know when there is too much paper on top of the printer and it stops so that the papers do not continue to feed out and overflow.
Either the flag is stuck in the up position, in which case you can just gently move it so it is hanging straight down, or the flag has been broken off and no longer functional ( in which case the flag and/or sensor would need to be replaced).
SOURCE: Scanner lockup
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.(You can apply little more pressure if it does not move easily)
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.(If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
SOURCE: Dell Photo printer 944 - error 2200
I think it might be the thicker of the two ribbons that go from the top of the printer to the bottom. Try to push it in a little more but be careful the little metal strips on it are really fragile I think thats what happened to mine
The error code that shows up is listed below.
System fault 0
Gzip.C
Line 423
Task Rip
