While watching game 6 of world series horizontal and vertical bars showed and picture went black with no sound and TV turned off. Now I try to turn on the TV and the power light flashes orange and then glows red.
SOURCE: LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from easywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at [email protected]
SOURCE: TV won't turn on - no picture or sound -and the
CK the fan behind blaster see if it is running, also a bad lamp will give 3 flashes then red, if 2 are green then red replace LAMP you dont have a power failure other wise if you did set would not show any of the LEDS.
SOURCE: Won't turn on with LG RU-52SZ61D 52 in. Rear Projection HDTV
The bulb you are buying is not the origianl one. The life of you bulb is too short, probably it was use before. Buy a original bulb and new.
SOURCE: LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
