Televison & Video Logo
Question about LG Televison & Video
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
I am looking at replacing the Power Supply with part number EAY40505202.
Posted by Dave I on
  • Dave I
    Dave I Jan 05, 2016
    Attached is a picture of what is displayed
Claude Kayser
    Top Expert:
  • LG Master
  • 9,098 Answers
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Posted on Jan 05, 2016
Testimonial: "Hi Claude, Thanks for your reply. However, I'm not clear as to what to do still. The capacitors on the power supply board dont show sign of bulging. Can you help clerify what the solution should be? Thanks"
  • 1 more comment
  • Claude Kayser
    Claude Kayser Jan 05, 2016
    Could you jump the capacitor with an identical one?
  • Dave I
    Dave I Jan 05, 2016
    Would you recommend replacing the entire power supply rather than fiddling with individual capacitors? More important, is the power supply board the solution? Thanks
  • Claude Kayser
    try this link LG 42LG70 LCD TV, has sound, no picture
Why do i have a green line on my tv
Vertical green lines on tv screen - Samsung 60" LED TV ... - iFixit
https://www.ifixit.com > Answers > View > Vertical+gre...
Jul 5, 2018 · 6 answers
Unplug all cables except the power cable, turn it on and see if you still have the green line. If without any image input, the line is there ...
How remove colored vertical lines all over screen of my LED ...
Dec 9, 2015
I have horizontal lines on part of my TV screen. - Sony Television
Dec 18, 2017
SOLVED: Why there's a green line - Samsung Television - iFixit
Aug 6, 2016
F-Series Vertical Green Line - Samsung Television - iFixit
Mar 8, 2018
More results from www.ifixit.com
Why does my TV have green lines on the screen? - Quora
https://www.quora.com > Why-does-my-TV-have-gree...
Sept 17, 2016 - With the green always on, it suggests that the cable the connects to the panel may have a bad line. Whether or not the cable has moved a bit to cause a short ...
6 answers · 10 votes: If its the same on every channel it means your TV is broke. I'm not tying to be a wise guy ...
There is a very thin green line going down my TV screen ...
Jan 3, 2021
How can I repair a TV with vertical lines on the ...
Dec 21, 2016
What causes a horizontal line on a flat screen TV? - Quora
Jul 25, 2018
What does it mean if a Samsung TV starts displaying ...
Jan 29, 2016
More results from www.quora.com
How to Get Rid of a Thin Green Line on an LCD - ItStillWorks
https://itstillworks.com > rid-thin-green-line-lcd-36231
A line of solid color indicates stuck pixels within your LCD. ... Your LCD produces specific colors and images by altering the colors of the thousands of tiny ...
5 tips to get rid of stripes on your TV screen - Coolblue
https://www.coolblue.be > advice > tips-for-removing-li...
Dec 18, 2021 - You can read 5 tips on removing horizontal or vertical lines on your TV screen here.
Vertical green line on Samsung LED TV : r/hometheater - Reddit
https://www.reddit.com > hometheater > comments > ve...
Apr 18, 2016 - It is most likely dead pixels within the monitor itself. You can try a stuck pixel video on YouTube that will flash colors or even give you a ...
This is Jon Baker from Sacramento, CA have a TV LG 50PZ55-UA have a lot of PICs that show model of the TV /boards - can you help on which board maybe the problem?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
What can I do to stop by iMac G5 LCD screen from being pixelated and getting dark blue and pink horizontal lines across it?
This very likely a failure in the LCD screen. If you are seeing thin or wide bands, vertical or horizontal across the screen, then you will need to have the unit serviced to repair or replace the screen. If the unit has been dropped or struck (hard) it is possible the connector cable for the screen has come loose, but this is not usually the issue. If the unit is still under warranty, get it serviced. If it is not under warranty, there are several good web sites that provide Do-It-Your-Self instructional videos as well as parts, both new and refurbished and used. If you google your specific model and "screen replacement", you will see a number of results appear that would be of use.
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Red screen, horizontal lines, 2'' black vertical bars both sides
it looks to me that you are not a technician becouse you are measuring at the wrong places risking a hazard shock if you have a little experience get the service manual and check your power supply and the h v capacitors near the horizontal output if not please take it to your service center
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Pink and green patches on screen
The thin red, green, or yellow/brown line you see running through your LCD is a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
1helpful
3answers
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Horizontal pixel line
I have seen this B4 here is a link that may help. http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Marvin
Marvin
Muzahura Frank
