Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
Posted on Sep 24, 2008
Channel Changing Hello, I have recently bought a different cable package that allows me to view channels 201-230, but I have no idea how to actually put those channels on through the remote. If I press the 2 and the 0 it goes to channel 20 automatically. I can't put in 2 0 1 for example. How do I do that?
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Sep 24, 2008
Anonymous
Contributor
Level 1:
Answers
33
Questions
Helped
14601
Points
81
Some TV's have a 115 to 125 channel limit then will go to video in and then channel 2 and start over. Your TV's tuner may not have the ability to decode those channels. My suggestion would be to get a set top box (cable box) that can access channels. Your provider should have these or can suggest where to get one. Probably less expensive than a new TV.
Price of armstrong western channel per month
Not sure if this is it:
http://www.conxxus.com/armstrong.html
Individual Pricing per Item:
Internet Services:
2 Mbps $29.95
7 Mbps $39.95
10 Mbps $49.95
Cable TV:
Basic Package: $12.00
Expanded Basic: $47.00
Digital Plus Package: $63.00
*Must have a DVR/HD box to view channels above Ch. 54
Premium Channels:
Cinemax Group: $13.00
Encore Group: $8.00
HBO Group: $16.00
Showtime/TMC Group: $13.00
Starz Group: $8.00
Phone: $39.95
*Includes: Unlimited local and long distance; caller ID and call waiting
Install Fee:$35.00
Package pricing:
2 Mbps/Expanded Basic Cable Package: $71.95
2 Mbps/Expanded Basic Cable/Phone Package: $89.95
2 Mbps/Digital Plus Cable Package: $87.95
2 Mbps/Digital Plus Cable/Phone Package: $117.95
7 Mbps/Expanded Basic Cable Package: $81.95
7 Mbps/Expanded Basic Cable/Phone Package: $99.95
7 Mbps/Digital Plus Cable Package: $97.95
7 Mbps/Digital Plus Cable/Phone Package: $127.95
10 Mbps/Expanded Basic Cable Package: $91.95
10 Mbps/Expanded Basic Cable/Phone Package: $109.95
10 Mbps/Digital Plus Cable Package: $107.95
10 Mbps/Digital Plus Cable/Phone Package: $137.95
I bought a 42inch snayo hdtv and i cant get it to recieve any hd cahnnels and was wondering why.
You need an HD Cable box from either your Satellite provider or the cable company, and you must subscribe to the HD package. The HD package is usually in a different channel range than your SD channels.
2helpful
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
2helpful
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Bought two pairs; not communicating with each other
Hi
If the second units are not working check power in those units, ar eyou sure they are on the same channel? also make sure the antennas are connected correctly.
good luck,
John.
4helpful
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Small number in corner Panasonic TC 63A61
If you cannot get the original remote or a more compatable aftermarket remote, you might try hooking up a VCR or Cable box to the auxiliary audio/video jacks and use that input while changing channels with the VCR/cableBox.
Digits dropped while changing channel
Make sure that you have the correct DTV box selected on the Tivo unit in the Guided Setup.
Make sure that the IR cables are directly in front of the IR eye on the Tivo.
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
