20 Most Recent Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Questions & Answers
Hello horndog78,
Your radio may be locked. You can confirm this by looking for a icon of a padlock on the screen.
To toggle the lock on and off hold down the LOCK/MODE button for a full two seconds until you hear a double beep.
Best Regards,
Ken
Go Ahead. Use Us.
Cobra MicroTalk... | Answered on Apr 29, 2016
one of the units may have a bad mic element. Can you hear the speaker unmute when the radio is keyed?
Cobra MicroTalk... | Answered on Nov 14, 2015
its most likely the switch, now sure how handy you are, but open it up & replace
in all honesty I'd throw it way & buy a new one they're cheap enough
Cobra MicroTalk... | Answered on Feb 08, 2015
Here is your manual
Cobra MicroTalk... | Answered on Sep 06, 2014
You can download the manual with all the instructions from here: https://www.cobra.com/sites/default/files/manuals/PR4500WX_MANL.pdf
Cobra MicroTalk... | Answered on Aug 02, 2014
Your description of "Glass encase 4mm reddish orange, black end." leads me to deduct that this is a diode. The black end denotes the cathode. For more help, post back.
Cobra MicroTalk... | Answered on Dec 09, 2013
Check to see if you have "tone squelch" or CTCSS enabled. It will only receive transmissions from stations that are transmitting the tone your radio has selected.
Cobra MicroTalk... | Answered on Nov 05, 2013
Very interesting, what happens if you turn it to channel 1? What channel is it on?
Cobra MicroTalk... | Answered on Oct 28, 2013
You may want to Buy the same thing, Go to store with yours, Have it turned on, When checking all they have, turn theirs on to see if you get good reseption
Cobra MicroTalk... | Answered on Aug 27, 2013
Have you tried sites like ebay, etc,...
Cheers,
Peter
Cobra MicroTalk... | Answered on Mar 04, 2013
Just in case these radios have been modified, or have lost there settings, please perform the following:
All radios must be tuned to the same channel and privacy code to communicate. To successfully communicate using a privacy code, both the sending and receiving radios must be tuned to the same channel and to the same privacy code system (CTCSS or DCS) and privacy code number. Each channel will remember the last privacy code system and number you select.
The privacy code 00 is not a privacy code, but allows all signals to be heard on a channel that is set to 00 on both the CTCSS and DCS systems.
Channels 1 through 7 are shared with FRS/GMRS. Channels 8 through 14 are FRS only.
Channels 15 through 22 are GMRS only.
To select a CTCSS privacy code:
1. After selecting a channel, press the Mode/Power button until the CTCSS icon appears and the small numbers next to the channel number flash on the display. If DCS is turned on at the channel selected, the display will flash the CTCSS icon and "OFF." To switch from DCS to CTCSS, press the Channel Up or Channel Down button while the display is flashing "OFF." The display will then show the small numbers flashing and you will then be able to proceed to step 2.
2. Press using the Channel Up or Channel Down button to select a privacy code. You can hold the Up or Down button for fast advance.
3. When your desired CTCSS privacy code is displayed, choose one of the following:
a. Press the Mode/Power button to enter the new setting and proceed to other functions.
b. Press the Lock button to enter the new setting and return to Standby mode.
c. Do not press any buttons for 15 seconds to enter the new setting and return to Standby mode.
To select a DCS privacy code:
1. After selecting a channel, press the Mode/Power button until the DCS icon appears and the
small numbers flash on the display (01 through 83).
2. Press using the Channel Up or Channel Down button to select a DCS privacy code. You can hold the Up or Down button for fast advance.
3. When your desired DCS privacy code is displayed, choose one of the following:
For Cobra Customer Assistance:
9:00 a.m. to 5:00 p.m. Eastern Time, Monday to Friday
(except Holidays) - (514) 683-1771, ext. 2-264 (phone).
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Cobra MicroTalk... | Answered on Jun 29, 2011
Your batteries may be bad. Sometimes over charging batteries will cause them to wear out.
Cobra MicroTalk... | Answered on May 05, 2011
put them both on the same channel
Cobra MicroTalk... | Answered on Oct 19, 2010
change battery. charge minimum 2 to 3 hours. charge only when your battery is nearly is finish.
Tenzin
Cobra MicroTalk... | Answered on May 12, 2010
replaced the units with another brand. Thks but no answer required.
Cobra MicroTalk... | Answered on Oct 24, 2009
Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Logo
Popular Tags
42 questions posted
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
one microtalk radios pr 4500 because
  • Radio Communications
