Gracenotehttps://www.gracenote.com
Gracenote is the leader in entertainment metadata, helping people connect to the music, TV shows, movies and sports they love across the world's most ...
Typically you insert a music CD disk and the unit will rip the disk into its music directory. This procedure uses Gracenote to populate the MySQL database with information about the album and each song. My current experiance is that the Gracenote interface code in the SMS3 is no longer suported by the current Gracenote network portal so the SMS database is not properly populated.
Unfortunetly the MySQL database schema is not simple to modify, having several tables and associated indicies. Try to connect from your browser to the IP address of the SMS3. You may have options there to add music to the import folder which will populate the music database sans the Gracenote info.
With no support from Russound to go further you will need to change the root password to one your own by attaching the SMS3 hard drive to a Linux computer. While you are doing that I suggest you (dd) a copy of the SMS disk for later use in case of disk failure. You can use this copy later to mank a duplicate disk for the SMS3. This is not trival and you will need help from a Linux or Unix System 5 tech to really do much on the server side. That said it is just a Red Hat Linux distro with some really great script software running the media server. Russound did custom the boot ROM on the VIA MOBO but that was just to get the splash screen and a video trick to work (just guessing about the video).
Philips music centre model 700/05 keep on saying booting please the other one is fine but the main unit which plays CD I have try all the trobleshooting but sill the power can't turn on how can I get the setup CD Rom
HI, check the version of your update. You might be using the wrong updating software to update or the update was interrupted. Make sure that you are using the right software update.
The best store for repairing is philips centre it might be in hyderabad i dont properly know the location but you can find the nearest store through phlips.com and click on store locater and enter your city and they will let you know the nearest philips centre.
Thanks and happy new year :)
Please rate it high.. :)
Hi i have just been able to sort this problem, if your system says "NO CD" after it is inserted then the CD is not sitting right inside, solution for this is, join the philips club (free) and update the firmware and update the Gracenote software 1, insert the cd so it is in then turn it off and unplug then take another cd insert it in slowly to push the other one down a bit until it stops (may only move a couple of millimetres, you are only using the cd as it fits the slot so don’t try and insert it!!) plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work OR 2, insert the cd so it is in then turn it off and unplug then you can open the product and physically push the cd down (be careful when you take the lid off as the cd will not be fully slotted down and there are a couple of cables that can pop out but they are easy to put back and obvious) Put the lid back on and plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work any probs just mail back and ill help as much as i can
After the MP3 songs are transferred from the PC to the Music Center via DMM, do not disconnect the power cord. The Center is updating its internal database to mark the changes of music library. Wait for around 20 minutes to let the Center update the database completely. When the internal updating is complete, you will be allowed to turn the Center into ECO Standby mode.
First, you have to download a cd player software of some sort, i.e. itunes, wmp, or realplayer. Once it is downloaded on to the player, you can sync your iriver with the player and you will have fun music to listen to on your mp3 player:)
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
