Sir try to check the fuse in the power supply may be damage. Remove the back cover of your unit but be sure to unplug the unit from the main ac outlet. Then look for the fuse, if the fuse is defective, before replacing it observe if the fuse is totally burned if you see this sign don't just replace the fuse it indicates that it has a shorted parts in the power supply common parts are the regulator and bridge type rectifier, but if the fuse is just broken or still you can see the wire you can replace it and try to check if the unit will power up. Good day and best regards.
Please check the following steps to troubleshoot your problem:-
Check that the power cord is securely plugged into the power outlet.
Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
If the above steps won't work to your problem contact your dealer or customer support.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
